Scratchbuilders!: General
For general topics on scratchbuilding.
Hosted by Mike Kirchoff
Please Help Cutting Styrene
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Sunday, September 19, 2010 - 02:00 AM UTC
Hi guys. I'm in the process of converting a M-35 cargo truck into an M-109. I need to cut some straight lines in styrene to add the workshop on the back. I've tried using a straight edge and razor knife and just cutting it with a pair of scissors, but can't get a straight line. Is there any other way to make a straight cut? Please help.
Piltdown_Man
KitMaker: 5 posts
Posted: Sunday, September 19, 2010 - 02:50 AM UTC
Use a P-Cutter (it will cut a "V" into the plastic) and don't try and cut it through in one go. Instead, with the cutter take notch out of the card, turn it over and supporting one site of the cut, snap off the other side. Dress up the cut edge and then measure what you have so you can cut the next bit accurately.
PM
TreadHead
KitMaker: 5,000 posts
AeroScale: 370 posts
Posted: Sunday, September 19, 2010 - 05:44 PM UTC
Howdy retiredyank,
Our good Piltdown_Man (?) has a good suggestion, and one that will work dandy.
My first question is, what is the thickness of your sheet? Because, in most cases a rubber-backed metal ruler is the most simple tool for the job you describe...just simply place along your cut line, score 2 or 3 times, turn over and place the sheet along the outside edge of your modeling table and, Voila!!
hth
Tread
retiredyank
AeroScale: 79 posts
Posted: Monday, September 20, 2010 - 02:48 PM UTC
It scored perfectly, just needed a sharper blade. Thank you.
TreadHead
Posted: Monday, September 20, 2010 - 02:52 PM UTC
good to hear
Tread.
BM2
#151
Virginia, United States
KitMaker: 1,389 posts
AeroScale: 28 posts
Posted: Friday, April 19, 2013 - 10:35 AM UTC
I use this alot...
http://midwestprod.web128.discountasp.net/item_detail.asp?item_id=23
PantherF
KitMaker: 6,188 posts
AeroScale: 25 posts
Posted: Saturday, April 20, 2013 - 02:35 AM UTC
I use a straight edge and "score" the plastic deep enough to then place the cut against the edge of a desk and then snap it off.
If it's too thick then a hobby saw would be better.
~ Jeff
