Armor/AFV: Techniques
Sticky time
redrsxs
KitMaker: 13 posts
Posted: Saturday, April 02, 2011 - 02:37 AM UTC
I recently bought Tamiya glue and what a difference with the Humbrol one. Better adhesion in less time. I saw Tamiya make some thin glue, I don't know whats the big difference. I'm not a big fan of they're big brushes, they should make one with springe system.
Anyway I would like to know which glue are using?
vonHengest
KitMaker: 5,854 posts
AeroScale: 372 posts
Posted: Saturday, April 02, 2011 - 05:25 AM UTC
Not sure I fully understand your question. Are you asking us what glue(s) we use? Or are you asking which of the glues you mentioned are better? Or something else entirely?
redrsxs
KitMaker: 13 posts
Posted: Saturday, April 02, 2011 - 05:32 AM UTC
sorry for my english. I was asking wich one are you using?
russamotto
Utah, United States
KitMaker: 3,325 posts
AeroScale: 369 posts
Posted: Saturday, April 02, 2011 - 05:57 AM UTC
Tamiya extra thin. It has a very nice, pointy brush, but it can be easily replaced with the brush of your choice.
vonHengest
Posted: Saturday, April 02, 2011 - 06:09 AM UTC
I like the Tamiya glue, especially for smaller parts because it doesn't leave any excess when you attach the little pieces. I use Testors when I want to really fuse the plastic together, and I use Loctite CA Control Gel or Gator Glue for everything else. I usually apply the glue with toothpicks.
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
AeroScale: 25 posts
Posted: Saturday, April 02, 2011 - 06:15 AM UTC
Tamiya thin green cap, absolutely! I can't live without
It's the only glue which allow you to match the parts and apply the glue AFTER.
It dryes very fast and it it's incredible thin. It doesn't leave ANY sign...
You can use as a putty thinner and i've noticed that a light coat of thin glue can remove little seads.
When you sand plastic parts and you need to clean the rough surfaces, you can aplly a thin coat of Tamiya glue and that works wonderfully...
Headhunter506
KitMaker: 1,528 posts
AeroScale: 44 posts
Posted: Saturday, April 02, 2011 - 07:08 AM UTC
I only use di and trichloromethane solvents. Better bonding than regular plastic cements. Very little post work required to clean up seams. I've been using them for over 35 years and would never consider going back to regular cements. Unlike regular cements, trichlo allows you to bond acrylic, ABS and butrate to styrene. This makes a big difference when you're scratchbuilding parts from dissimilar materials.
Zap-A-Gap thick CA with a shot of accelerator is fantastic for filling annoying gaps. Unlike the dissolved sprue in liquid cement method, the CA won't damage the surrounding plastic.
I've tried Gator Glue; but, it's no better than white glue, in my opinion. No tensile strength; not the greatest stuff for attaching PE because of this. If it's PE to PE, I'll solder them.
junglejim
KitMaker: 1,709 posts
Posted: Saturday, April 02, 2011 - 07:42 AM UTC
Plain old Testors liquid cement 75% of the time, Tamiya Extra Thin (green cap) for the rest.
Jim
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Saturday, April 02, 2011 - 07:46 AM UTC
I use Hobby Time in the purple bottle. The tip allows for precision glue application and it will bond almost anything.
Violetrock
KitMaker: 815 posts
Posted: Saturday, April 02, 2011 - 08:02 AM UTC
I use MEK known as Butanone and butyl acetate
I use MEK when an extremely fast bonding is needed, butyl acetate when a slower bonding is neeeded or I need to melt the plastic for weld seams, cast structure, etc.
TonyDz
KitMaker: 420 posts
Posted: Saturday, April 02, 2011 - 01:20 PM UTC
Jim
Ditto. I find the Testors gives a stronger join than the Tamiya.
As said else where, you can always use a finer brush.
You can do the same with Testors.
Spiderfrommars
Milano, Italy
AeroScale: 25 posts
Posted: Saturday, April 02, 2011 - 06:19 PM UTC
Very interesting indeed. Me too I've noticed that common plastic glues give some problems in scratch works, especially when I use plastics different from Polystyrene Where do you buy it?
Anyway, to be more exhaustive for stronger bonding I use or the Tamiya orange (or withe) cap glue or Faller expert glue.
Headhunter506
AeroScale: 44 posts
Posted: Saturday, April 02, 2011 - 06:42 PM UTC
Very interesting indeed. Me too I've noticed that common plastic glues give some problems in scratch works, especially when use plastics different from Polystyrene Where do you buy it?
Can't help you on where to buy the solvents in Italy. Living in New York, I can buy the stuff from a really well stocked art supply store, like Pearl Paint, or at numerous places that specialize in sheet and formed plastic, acrylic and vinyl stock. You should be able to locate one place or the other near you. You could also try a chemical supplier.
Spiderfrommars
Milano, Italy
AeroScale: 25 posts
Posted: Saturday, April 02, 2011 - 07:17 PM UTC
Thanks a lot for the advice. I live in a big city so I think I'll be able to find it. Actually I have already in mind a place where I can buy it
I just hope it won't be expensive and sold in large amounts....I wouldn't like to stock in my flat a lot of very flammable stuff
Thanks a million !
jashby
KitMaker: 278 posts
Posted: Sunday, April 03, 2011 - 01:04 AM UTC
I use Plastructs' Weldene (MEK) and Bondene mainly. Have only just gotten hold of the Tamiya Green Cap and it seems alright.
I used to use Revells Contacta Professional cause of its easy to use needle point applicator and I have used Humbrols Liquid Poly in the past with good results.
For CA I prefer Zap but it was hard to get in Oz for a bit so I have used BSI (Bob Smith Industries) which is the same as Zap.
Bugger, just read the labels on the Plastruct and they say that "This product contains a chemical known to the State of California to cause cancer". Lucky I'm in the State of Queensland so I'm safe. Same reason I only smoke cigarettes with the label "Your smoking can harm your unborn baby", bit hard to harm it when its a medical impossibilty for me to get pregnant. But then Arnie did it and he's the Govenor of California. Coincedence maybe?
Cheers, John
Headhunter506
AeroScale: 44 posts
Posted: Sunday, April 03, 2011 - 06:08 AM UTC
Cheers, John
Ignore the California-related warnings. The entire state is waiting for the mothership to arrive. Plastruct's Plastic Weld is good for bonding dissimilar plastics to each other. If you go to a plastic supply store, you'll get more bang for your (insert your local currency here). For example, Tenax-7R (repackaged bulk DCM) is sold in 1 oz. bottles which sells for almost $5.00 in some places. You can go to the aforementioned plastic supply house, or home improvement center, and get a pint container of IPS Weld-On 4
for about 13 bucks.
russamotto
Utah, United States
Posted: Sunday, April 03, 2011 - 03:32 PM UTC
BSI is great CA glue. It is sold locally either under that name or with a paste on label for the local shops. I use their odorless formula as it is much easier on the eyes.
Spiderfrommars
Milano, Italy
AeroScale: 25 posts
Posted: Sunday, April 03, 2011 - 05:34 PM UTC
Unfortunately IPS Weld-On 4 is not on sale in Europe
I'll have to find an alternative product
Tankrider
Oklahoma, United States
KitMaker: 1,265 posts
Posted: Monday, April 04, 2011 - 03:05 AM UTC
I used to use Tamiya thin but went to MEK. Quick drying, strong joint and realitivlt cheap at beteen $6.00 -8.00 for a quart can at Home Depot or Lowe's. I did retain the tamiya bottle(s) and brushes for applying the MEK. I also no longer cuss when I leave the top off and lose half a bottle of Tamiya Thin from evaporation.
John
