Tools & Supplies: Compressors
Talk about compressors.
Hosted by Matt Leese
my compressor
PanzerKarl
KitMaker: 2,310 posts
AeroScale: 35 posts
Posted: Saturday, March 07, 2015 - 11:49 AM UTC
Just bought myself a new compressor and after about 20 minutes or so it gets quite warm and starts to give off an oily smell,is this normal with this type of compressor?
Karl
ejhammer
Michigan, United States
KitMaker: 214 posts
Posted: Saturday, March 07, 2015 - 07:21 PM UTC
I would say yes. I have owned 20 or more compressors over the years of all types.
First, the act of compressing a gas (air) creates heat. That's why the compressor head has fins on it - to dissipate that heat. Any electric motor running also creates heat, again usually dissipated by fins or an internal fan to cool the windings, (the little slots in the cover of the motor).
The smell comes from the off gassing of oils, lubricants and coatings used in the production of the compressor and motor. This will cease to be an issue after a while, kinda like when the heater in your car or a new toaster is fired up the first few times.
Enjoy your new compressor.
EJ
CMOT
KitMaker: 10,858 posts
AeroScale: 281 posts
Posted: Saturday, March 07, 2015 - 07:28 PM UTC
I have a compressor that looks exactly the same as this one. It does get warm during heavy use but I have not noticed an oily smell being given off. If this is the same compressor as I have it has done stirling service for 6 years now and required no work to be done to it.
PanzerKarl
AeroScale: 35 posts
Posted: Saturday, March 07, 2015 - 10:17 PM UTC
Thanks for your replies.
I found a little mod that I am going to do,I have ordered an 8cm CPU fan from ebay for 1.79 and some 9v batteries and attach it to the back of the compressor,should keep it a lot cooler.
Ill post some pictures up once I have done it.
Regards
Karl
edmund
KitMaker: 668 posts
Posted: Monday, March 09, 2015 - 05:37 PM UTC
Maybe it would be better if get one of those small 12 volt power supplies , the one you plug into the wall , it would be easier to wire up the fan than to keep buying batteries . Or maybe look for a line voltage fan , is it 220 v AC ?
PanzerKarl
AeroScale: 35 posts
Posted: Monday, March 09, 2015 - 08:58 PM UTC
I fix the fan to the compressor and it works ok.done about half hour painting last night and it was not as hot as it was.
Karl
Alystyr
Ohio, United States
KitMaker: 146 posts
AeroScale: 11 posts
Posted: Monday, March 09, 2015 - 09:51 PM UTC
Really creative mod!
I second Edmund's comment about getting a 12V power supply. Since PC fans like that one you used normally run at 12V anyways, it should be perfect and not affect the life of the fan at all. You could probably find one really cheap at a thrift store, but even new they don't cost all that much.
pseudorealityx
KitMaker: 2,191 posts
AeroScale: 11 posts
Posted: Monday, March 09, 2015 - 11:47 PM UTC
I'm not sure how you've arranged the fan, but it should be pulling air OUT of the motor, not blowing into the motor. It'll be more efficient that way.
PanzerKarl
AeroScale: 35 posts
Posted: Tuesday, March 10, 2015 - 12:42 AM UTC
The fan is blowing air in to keep the motor cooler.
edmund
KitMaker: 668 posts
Posted: Tuesday, March 10, 2015 - 12:55 AM UTC
Have you considered a compressor with a tank , that way when the tank is full the compressor will stop , this one you got it keeps on running when you pause airbrushing ?
pseudorealityx
AeroScale: 11 posts
Posted: Tuesday, March 10, 2015 - 01:00 AM UTC
Based on the photo at the top of the thread, there's some small vents at the bottom of the compressor. You want to pull the air through those vents, through the coil/windings and then out with the fan.
Flip your fan around and it'll work better.
CMOT
Posted: Tuesday, March 10, 2015 - 01:02 AM UTC
As I believe I have the same compressor the answer is no, it shuts down except when you are spraying. I got a large bore airline which works as a tank for a small amount of air.
PanzerKarl
AeroScale: 35 posts
Posted: Tuesday, March 10, 2015 - 01:54 AM UTC
Jesse that part at the top has no vents its just a solid piece of metal.
CMOT
Posted: Tuesday, March 10, 2015 - 02:07 AM UTC
Karl he means the slots on the bottom of the motor body.
Alystyr
Ohio, United States
KitMaker: 146 posts
AeroScale: 11 posts
Posted: Tuesday, March 10, 2015 - 02:16 AM UTC
Possibly true.
The fan should be set so that it works with the original flow of air, however that is, instead of against it.
Say, if the compressor draws in through the bottom vents, then the fan should pull air through (label out, if the polarity's correct) the motor.
If it's set wrong, it really won't hurt anything. It just won't be nearly as efficient.
