Armor/AFV: Softskins
Softskins group discussions.
Building A Kraz Tank Transporter
OldWarloke
KitMaker: 2,308 posts
Posted: Tuesday, March 24, 2015 - 10:08 PM UTC
I just finished the double Abrams build and decided on something different.
This will be mostly straight out of the box.
Here are the Sprue from the TAKOM kit #2019
Ukraine Tractor KRAZ 6446 with ChMZAP-5247G SEMITRAILER
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:16 PM UTC
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:23 PM UTC
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:26 PM UTC
Well that's the Sprue from this kit.
I'll have some Pics. when I get some of it built.
Donald
OldWarloke
Posted: Wednesday, March 25, 2015 - 08:27 PM UTC
Here is the start of the actual build.
First off the instructions aren't clear on a lot of the assembly steps, (how & exactly where the parts go)
This build is how I built it, you may choose a different way.
I mean I an not an expert, I just like to build these.
Starting.
Glue the 2 G18 & G19 parts together & fill the seams.Then Glue them to part F2 , filling & sanding the square openings on the back of F2. Then glue F2 to the lower trailer frame using the top frame to assure the correct position.
Glue the end of H27 to H30 as shown then glue H30 to H25 don't glue H27 to H25 yet. then glue G8 to H25 keeping the angled end pointed toward H30 .
You can glue F13 to F1 now or later.
There are 2 large Pushpin marks on F1 that should be sanded down.
OldWarloke
Posted: Wednesday, March 25, 2015 - 08:52 PM UTC
Repeat the previous steps with H26, H31, H28, & G8.
Above shows the assembly installed.
The instructions aren't verry clear on how the G8 parts go, this is how.
OldWarloke
Posted: Wednesday, March 25, 2015 - 09:00 PM UTC
Install F11 in the end of the bottom frame angling it so the top edgr is just behind the edge of the opening.
Then glue the top & bottom together.
You can slip in the F1 / F13 assembly in from the bottom.
Note placement of F1
The top of F1 should match the top edge.
OldWarloke
Posted: Wednesday, March 25, 2015 - 09:09 PM UTC
Here is H6 installed.
There are 2 spots on the bottom where F11 attaches, these will need to be filled.
There is also a small gap on the ends of F1 that will need to be built up.
That's all for now.
Donald
chefchris
KitMaker: 1,537 posts
Posted: Wednesday, March 25, 2015 - 11:05 PM UTC
Super !! I love this kit. Im looking forward to seeing how it goes. I haven't built any of the Takom kits yet, but they look well engineered and accurate.
Chris
chefchris
Posted: Thursday, March 26, 2015 - 12:40 AM UTC
Whats going on the trailer? ...
pgb3476
KitMaker: 953 posts
Posted: Thursday, March 26, 2015 - 12:49 AM UTC
I am wondering what's going on the bed too....
OldWarloke
Posted: Thursday, March 26, 2015 - 05:02 AM UTC
I don't know yet. I wonder who else besides the Ukranians use this beast?
Donald
OldWarloke
Posted: Thursday, March 26, 2015 - 08:35 PM UTC
You are going to need something like this to bend the Photo-Etch parts.
There are a lot of itty-bitty Photo-Etch parts for the trailer track guards. I think that's what they are called?
Back to work.
Donald
OldWarloke
Posted: Friday, March 27, 2015 - 05:04 PM UTC
This finishes step 9 of the instructions'
Had to fill some sink marks on the bottom.
I'm working on the loading ramps next.
Donald
OldWarloke
Posted: Saturday, March 28, 2015 - 01:40 AM UTC
You will need G13 G20 G21 G11 & G5 for both left & right ramps.
The only difference between the ramps is for one side you use H1 H3 & H42 the other side uses H2 H4 & H41
It is important that the beveled area on H42 & H3 match up also the bevel on H41 & H4
Parts G2 G39 & G45 are the same for both ramps.
Back to work now.
Donald
Armored76
Bayern, Germany
KitMaker: 1,615 posts
AeroScale: 51 posts
Posted: Saturday, March 28, 2015 - 10:23 AM UTC
Now this is going to be fun! I'll definitely keep an eye on this blog.
OldWarloke
Posted: Saturday, March 28, 2015 - 08:38 PM UTC
I made the ramps removable for ease when painting.
There is a small curved pad that goes where the 2 openings are, I left it off until after painting because there is a red & white striped decal that goes there.
I'm not sure where the arm conected to the hinge pin goes, there is no information on the instructions.
That's all for now.
Donald
OldWarloke
Posted: Sunday, March 29, 2015 - 07:49 PM UTC
I have been working on the goose neck part of the trailer, there are some fit problems here. I think I got it right, but the instructions contradict each other.
There is a slight angle on the ends of the first two cross members.
The winch cable guide glues only on the top edge.
If you don't have the front plate of the goose neck flush with the side frames the sole plate where the trailer hooks to the tractor will not fit right.
There are winch cable guides on the trailer, but NO WINCH ON THE TRACTOR.
If you fit the front end right, there is a gap at the back to be filled.
More later.
Donald
OldWarloke
Posted: Monday, March 30, 2015 - 10:14 PM UTC
I have the goose neck of the trailer finished except for the front ground struts.
I'll be working on the trailer wheels next.
Donald
pgb3476
KitMaker: 953 posts
Posted: Monday, March 30, 2015 - 10:35 PM UTC
Looking very good. Building up like the Trumpeter trailer.
vettejack
KitMaker: 1,060 posts
Posted: Tuesday, March 31, 2015 - 12:04 AM UTC
Maybe this pic might help with your transporter ramp issue (not my model, but I wish it were!) ...
OldWarloke
Posted: Tuesday, March 31, 2015 - 09:11 PM UTC
I have the parts for the wheels cleaned up.
I glued a thin strip inside the outer wheel to hold the axel pin in position when the wheels are assembled.
The wheels are assembled, & Tires fitted to some.
The Tires fit pretty good by slipping over the assembled rim.
Here is the Trailer Axle Bogie.
It needs a little filling on the bottom.
More tomorrow.
Donald
OldWarloke
Posted: Wednesday, April 01, 2015 - 07:20 PM UTC
I have the Trailer mostly finished.
The spare wheels aren't fastened down, that's for after the painting.
OldWarloke
Posted: Wednesday, April 01, 2015 - 07:27 PM UTC
Here is a comparison between the Takom Trailer and the one from Trumpeter.
The Green one is from Trumpeter & the tan from TAKOM.
