Tools & Supplies: Compressors
Talk about compressors.
Hosted by Matt Leese
Compressor punctured
alewar
Canelones, Uruguay
KitMaker: 771 posts
Posted: Friday, August 07, 2015 - 10:12 PM UTC
Hi, todas my trusty 25 liter compressor start to leak at the bottom .it's possible to fix it with a metal screw and some adhesive as poxipol or araldite?.
It's safe ?. I will buy another's one ASAP. Biut I have a model half painted.
Regards from the south Alvaro
ejhammer
Michigan, United States
KitMaker: 214 posts
Posted: Friday, August 07, 2015 - 11:32 PM UTC
I have done that. Also used band clamps and rubber gasket.
I don't know what compressor/tank combo you have, but the best way is to replace the tank. I've used tanks from W W Grainger, but other industrial supply houses have them as well. Beats buying a whole system when you can get just the tank and swap out the wheels, compressor and such. Cheaper too. Just need to drain down the tank more frequently so it doesn't rust out the bottom.
EJ
alewar
Canelones, Uruguay
KitMaker: 771 posts
Posted: Saturday, August 08, 2015 - 03:52 AM UTC
Hi Eugene, I follow your advice and fix the compressor. I drain it once a year but seems that I must do it often.
I load the tank with half of the max pressure and now don't leak.
Regards Álvaro.
edmund
KitMaker: 668 posts
Posted: Saturday, August 08, 2015 - 09:24 AM UTC
It will later on . Consider welding the hole ? It might be lot of trouble to take the tank to a welding shop but might not be a bad idea in the long run .
Namabiiru
MODEL SHIPWRIGHTS
#399
Rhode Island, United States
KitMaker: 2,794 posts
AeroScale: 305 posts
Posted: Saturday, August 08, 2015 - 11:55 AM UTC
For my part, I wouldn't risk adding more shrapnel to a potential catastrophic failure. Safer just to replace the tank. Make sure you drain it regularly, especially if you live in an area where the air is damp and/or salty.
AFVFan
KitMaker: 1,980 posts
Posted: Wednesday, August 19, 2015 - 12:21 PM UTC
Regards Álvaro.
Don't put a lot of faith in patch jobs. Get through what you need done and replace the tank as soon as possible. Drain the tank at least once a week, especially if, as Mark mentions, you live in a high humid climate.
