I used Evergreen sheet for the stand off armor. 1.5mm I think. I'll have to measure later tonight. I'm thinking of making an enclosure of some type on the rear deck for infantry. I've seen it done on some very late war Panthers but I can't find any picture of actual vehicles where you can see inside the enclosure to see if the deck vents are protected. I could probably come up with something that would work, even if it were along the lines of the AA armor used just over the vents.
I was thinking of putting this in a Leningrad/Stalingrad type scene circa 1946/47 alternate time line idea. Maybe in front of a destroyed clothes shop or department store as a tip of the hat to Enemy at the Gates. This Panther II was from the Cyberhobby white box and has the Volksturm infantry with it, which really aren't Volksturm IMO. They look like healthy military age men, not old men and boys. So I was going to use them in the dio along with a tank commander and bow gunner. I like the idea of the ammo trailer, just have to find one, then make the Panther II tow hitch as Dragon never included it with any of the releases. It's significantly different from the kit provided hitch.
You're right about the Volksstrurm- I think DRAGON confused the Volkssturm with the various Volksgrenadier Regiments- The Volksstrurm was comprised of poorly-equipped "conscripted" old men and young boys; the Volksgrenadier Regiments were actual HEER, and were highly-trained and motivated...
I like how this build is progressing- Most of everything is believable, from a technical standpoint. I say "most", because all that extra armor (especially with the 2"-thick "Side-Skirts"), would weigh quite a bit, which begs the question:
Since Panthers and Tigers I & II were under-powered, (Engine Bay fires were quite common), and were plagued with unreliable Transmissions and Final Drive Units, wouldn't larger, more powerful Engines need to be used, as well as more robust Transmissions and Final Drives..? But since this is a "What If...", I suppose the Germans might POSSIBLY have come up with properly executed Engines, Transmissions, Final Drives, etc, but I seriously doubt that the Germans could have turned the war around to the point of lasting into 1946-'47, since they were already on their last legs by the Winter of 1944-'45. By that time, they were already resorting to "last ditch efforts" such as the aforementioned Volksstrurm...
In any case, this looks like a really nice project!
NICE GOING, Bob!!!
PS, and a question- I forgot to mention in one of my earlier posts in this thread that besides my "Sturmpanzer" E-25, I also built a hypothetical "E-101", which turned out to be a more "refined" E-100, using the old DRAGON E-100 kit. I scratch-built a new Turret, creating a much larger, heavier, more "modern" Turret, with a more "streamlined" shape, a la the earlier Tiger II Porsche-designed, Henschel-built Turret. The Main Gun Mantlet was re-worked, and the unlikely "coaxial" 7.5cm PaK 40 (WITH a Muzzle Brake), was gleaned from a spare TAMIYA PaK 40 kit. I gave the heavy Side Skirts a more "streamlined" shape, and I added Tools, Towing Cables, and Gun Tube Cleaning Rods to the Skirts, as well. I painted this monstrosity in a conjectural "Quad-color" mottled-camouflage scheme of DUNKLE-GELB, OLIVE-GRUN, and PANZER SCHWARTZ-GRAU over RED-BROWN PRIMER, which I incorporated as part of the "Quad-color" camo. I used the Suspension and Tracks staright out-of-the-box...
Anyway, for a "Paper-panzer"", I'm pleased with it...
Question: What are you going to use for Wheels and Suspension, if not the ones you showed in your last pic? Just curious...
