P-51D Cowling Access Panel Evolution
n_tuma749
Nebraska, United States
KitMaker: 45 posts
AeroScale: 31 posts
Posted: Tuesday, November 15, 2016 - 04:44 AM UTC
How did the size, shape, and number of access panels on the P-51D's engine cowling change over its production run (blocks)? I ask this as I have noticed that not every P-51 production block has the same number or size of panels, and would like to know which panels to remove or add depending upon the version I'm building. The Tamiya 1/32 P-51D has;
Top of cowling, left (from the pilot's point of view) side:
Hydraulic reservoir access panel
Oil tank access panel (this is apparently the larger type)
Aftercoolant access panel
Bottom of cowling, right (from the pilot's point of view) side:
Ground heater duct access panel
Unmarked access panel
Bottom of cowling, left (from the pilot's point of view) side:
Fuel strainer access panel
KitMaker: 6,743 posts
AeroScale: 6,151 posts
Posted: Wednesday, November 16, 2016 - 06:03 AM UTC
What scheme are you planning on doing ? Knowing the tail numbers would be helpful ....
