Tips & Tricks
Attaching metal to painted turret.
Mortifa
#464
KitMaker: 172 posts
AeroScale: 7 posts
Posted: Friday, December 23, 2016 - 09:02 PM GMT+7
Just getting back into the hobby and started doing a build and changed my mind about the tank, but, now I want to add some wiring which appears to be attached to the turret.
Do I drill holes where the wire begins and ends and just use super glus? Would hot glue be better and I should paint he wire before attaching?
The one I am trying to make looks like the one in my gallery, for some reason I cannot get the image to show.
I do hope I posted this in the right forum?
retiredyank
#160
Arkansas, United States
KitMaker: 11,042 posts
AeroScale: 79 posts
Posted: Saturday, December 24, 2016 - 03:59 AM GMT+7
I recommend you paint the wire, before gluing it. As far as glue, pva should work fine.
Mortifa
#464
KitMaker: 172 posts
AeroScale: 7 posts
Posted: Saturday, December 24, 2016 - 04:12 AM GMT+7
Thanks for the response, PVA is just white glue?
retiredyank
#160
AeroScale: 79 posts
Posted: Saturday, December 24, 2016 - 09:40 AM GMT+7
Yes, pva is white glue.
KitMaker: 15,851 posts
AeroScale: 1,458 posts
Posted: Friday, December 30, 2016 - 02:23 AM GMT+7
PVA glue doesn't hold worth a crap. It should only be used to glue clear parts. I would do as you initially thought, drill where the wire goes into the turret and glue with superglue. I would also paint it after gluing since the glue can/will stick better to the wire. Paint just adds another layer to be pulled off as the paint will pull away with the superglue. Paint is a very weak bond.
Mortifa
#464
KitMaker: 172 posts
AeroScale: 7 posts
Posted: Saturday, December 31, 2016 - 10:05 PM GMT+7
Thanks, I was still pondering which way to do this, and trying to get some wire to go the way I want.
This is the tank I am trying to model, but I found it after I had already started, lesson learned.
And this image is where I am at now, just waiting for the decals to dry before another layer of clear coat and then start weathering and such.
retiredyank
#160
AeroScale: 79 posts
Posted: Saturday, December 31, 2016 - 10:46 PM GMT+7
So long as it is not supporting anything heavy, pva works great. I use it for small etch assemblies and figures, with excellent results.
Posted: Tuesday, January 03, 2017 - 04:31 AM GMT+7
To each their own. I find the bond w/PVA too weak to hold anything for any length of time. For me, the only thing it remotely holds sort of well is paper items like ration boxes.
Namabiiru
#399
Rhode Island, United States
KitMaker: 2,420 posts
AeroScale: 282 posts
Posted: Tuesday, January 03, 2017 - 05:18 AM GMT+7
Normally, I would go with CA glue as well, but if you drill through the turret and glue from the inside I think PVA would work okay. Gluing from the inside keeps things neater and gives you an unpainted surface to glue to. I would probably prime the wire first and then paint it after installing.
Mortifa
#464
KitMaker: 172 posts
AeroScale: 7 posts
Posted: Tuesday, January 03, 2017 - 08:16 AM GMT+7
Sadly I had already gotten a lot of the model built and painted before I really notices the wire.
So I tried some thing, that did not work.
But where the wire was it left a pretty cool looking chip effect.
On a positive note I did learn a lot this build that I hope to use in future builds, including the research BEFORE I start building. My first armour kit in over twenty some odd years and I think it looks okay.
Namabiiru
#399
Posted: Tuesday, January 03, 2017 - 10:00 AM GMT+7
Looks great, Richard!
