Tips & Tricks
Questions about bricks in 1/72nd scale
Wolf-Leader
New Hampshire, United States
KitMaker: 1,109 posts
AeroScale: 49 posts
Posted: Friday, June 09, 2017 - 08:39 AM UTC
I am making a German RR diorama in 1/72nd scale and would like to ask a couple of questions.
1.Are there companies out there that make bricks in 1/72nd scale? Meaning bags of bricks and/or straight brick walls,no corners.
2.If not and I have to scratch build them,what would the dimensions of a brick be in this scale?
3.Are there tutorials on how to make bricks in this scale and NOT 1/35th scale?
Thank you and I hope you can help and information is appreciated.
Vicious
KitMaker: 1,021 posts
AeroScale: 48 posts
Posted: Friday, June 09, 2017 - 09:15 AM UTC
Juweela make them in different colors,size and style,
http://www.juweela.de/de/produkte/massstab/sc/172.html
I've bought the rubble for a job and are perfect, with a bit of patience you can separate the various types and colors of bricks and in practice you find yourself with a mix of a bit of everything, including wall pieces, etc...later i can post a picture of my work in 1/72 that I almost finished with the Juweela stuff...
Rubble mix different colors:
http://www.juweela.de/de/produkte/massstab/produkt/sc/172/no/truemmer_grau_rot.html
Staff MemberTOS Moderator
KitMaker: 3,187 posts
AeroScale: 6 posts
Posted: Sunday, June 11, 2017 - 08:52 AM UTC
Brick rubble:
If the heap of bricks come from a bombed or otherwise destroyed building there would be remnants of mortar (the greyish stuff that is used to "glue" bricks to each other).
Walls:
If you plan on making brick walls or any type of construction then make sure to check a real brick wall first. Real bricks are not laid in the same manner as LEGO-bricks ...
A starting point in the fine art of bricklaying
https://en.wikipedia.org/wiki/Brickwork
Stretcher bond is LEGO-type and can not stand alone, it must have some kind of supporting and load carrying structure behind it.
Remember: A brick wall is not thick as a brick, it is usually quite a bit thicker than a brick.
/ Robin
https://de.wikipedia.org/wiki/Mauerziegel
1872: 25 cm × 12 cm × 6,5 cm
Sometime later: 24 cm × 11,5 cm × 6,3 cm
or 24 cm × 11,5 cm × 7,1 cm
I'll let you divide by 72
Reichsformat
Industrialisierung und Eisenbahnbau ermöglichten den Transport von Baumaterialien über größere Strecken und die Lieferanten mussten austauschbar sein. So wurde 1872 in Deutschland per Gesetz das „Reichsformat“ für Ziegel (heute „altes Reichsformat“) eingeführt: 25 cm × 12 cm × 6,5 cm. Damit konnte ein Gebäude aus Mauerziegeln verschiedener Herkunft erbaut werden. Für staatliche Bauten war die Verwendung dieser „Reichsziegel“ verbindlich. Für andere Gebäude war es wirtschaftlicher geworden, normierte Ziegel zu verwenden und herzustellen. Dieses Ziegelformat wurde 1869 von dem Berliner Baumeister Lämmerhirth vorgeschlagen. Damit wurde die Anzahl mit dem Planungsmaß 1 Kubikmeter Bauwerk verbunden. Ein Kubikmeter Mauerwerk inklusive 1 cm Fuge und üblichen Verlusten an den Ecken bestand aus 400 Ziegeln.
Mit dem metrischen System wurde das (neue) Reichsformat mit 24 cm × 11,5 cm × 6,3 cm und das Normalformat mit 24 cm × 11,5 cm × 7,1 cm notwendig. Mit dieser Ziegelgrundfläche und einem Zentimeter Mörtelfuge waren die Bauten in 1/8-Meter-Einheiten gerastert (oktametrisches System). Durch eine fehlende oder zusätzliche Mörtelfuge bei Innen- und Außenmaßen ergibt sich immer eine Differenz von ±1 Zentimeter. Auf dieses Baurichtmaß genannte Raster wurden später die Maße anderer Baugewerke, wie zum Beispiel Fenster und Türen, abgestimmt und in ihren Maßen genormt.
Wolf-Leader
AeroScale: 49 posts
Posted: Monday, June 12, 2017 - 02:43 AM UTC
Thank you very much! this will be a big help!
