OFFICIAL: ANZAC Campaign 2017
KitMaker: 4,130 posts
AeroScale: 2,746 posts
Posted: Tuesday, December 05, 2017 - 09:51 PM UTC
Excellent work on the masking. I did the turret on my TBM by hand, and it did drive me crazy .
Used a lot of old circle templates to get some of the curves right and still managed to miss a frame on the other side that I had to add by hand.
KitMaker: 1,589 posts
AeroScale: 1,438 posts
Posted: Tuesday, December 05, 2017 - 11:55 PM UTC
Torsten .... buddy! Awesome work with the Ventura it looks just stunning. Loving the turret and I agree with you trying to mask that would've been a job and a half!
Mark nice masking job! I hear you about the turret it's bad enough in 1/48 scary in 1/72nd!
Pave-Hawk
KitMaker: 843 posts
AeroScale: 178 posts
Posted: Thursday, December 14, 2017 - 03:45 PM UTC
Finally going to make a start on my Boomerangs for this campaign.
will also be doing a bit of a build log as I go HERE.
Posted: Friday, December 15, 2017 - 10:46 AM UTC
Awesome Iain! I like the pugnacious lines of the Boomerang and I'd really like to see how the Special Hobby kits build up. Look forward to seeing your progress.
Baden-Württemberg, Germany
KitMaker: 1,195 posts
AeroScale: 1,068 posts
Posted: Saturday, December 16, 2017 - 04:30 PM UTC
Thanks Mark and Chris!
Ian, good luck for your dual build!
I have added 2 photos to the campaign gallery (the first!) and some more at my Assembly Line Thread. As you can see from Damian's post, this Ventura was most likely listed as SB-C in the RAAF inventory and not as SB-G, though on the inflight photo it looks very much like a "G". I wonder, where Hannants have got their informations from ....
Cosimodo
#335
Auckland, New Zealand
KitMaker: 1,099 posts
AeroScale: 182 posts
Posted: Sunday, December 17, 2017 - 01:56 PM UTC
Great finish on the Ventura Torsten! Obviously a favourite of yours.
And Mark, nice work masking that TBM, especially in that scale.
Cosimodo
#335
Posted: Sunday, December 17, 2017 - 02:06 PM UTC
I got the cockpit installed and the Spit closed up. The fit for the fuselage and wings was pretty good with only a little filler. The wing tips not so good though.
To convert the Mk11 to a Mk1 I filled a couple of areas on the nose.
The resin fabric ailerons are from Barracuda as are the radiator and oil cooler. I used some of Eduard's etch for the wheel well for some detail with the kit being fairly bare.
To be honest the resin parts, especially the radiator, took a fair amount of finessing to get them to fit.
The plane has been to the Tamiya primer shop to highlight any last flaws of which there a few.
I will fill a few gaps and with any luck I will get some colour on before Xmas.
Finally, what colour should the wheel wells be? Interior green or the exterior colour? or like a Hurricane, bare metal?
Posted: Friday, December 22, 2017 - 03:33 AM UTC
I've finally chosen my build for this campaign, it took a little bit of thought and I'm stepping outside my usual sphere of work. I'm going to build a 6 pounder portee of the 7th New Zealand Anti Tank Regiment 2ndNZEF western desert 1942. I've managed to find the marking info required at the MLU forum. I'm looking forward to the build, this is the old Peerless Max kit re-released by Italeri. Lets see what I can come up with. Do I post the build log here or over on Armourama, admins please advise? And of course the usual before photo's of the kit before I decimate the sprues.
IMG_1927 by Chris WIlson, on Flickr
IMG_1926 by Chris WIlson, on Flickr
IMG_1925 by Chris WIlson, on Flickr
IMG_1924 by Chris WIlson, on Flickr
Cosimodo
#335
Posted: Friday, December 22, 2017 - 01:16 PM UTC
Hi Chris,
That's looks like an interesting choice. I would build it just for the truck. Q. Why did they load the 6pdr on the back instead of just towing it? It must have been a b****r to load
Posted: Friday, December 22, 2017 - 05:28 PM UTC
Hi Michael I can think of a several of reasons, the gun is ready to fire no unlimbering and setting up, the crew are on the back of truck with the gun and ammo so it can quickly be brought to bear and lastly height at that height the gun can see a lot further than one on the ground. I've been reading the history of the Regiment and the 6 pounders were used to quickly silence several 88's that were decimating the 9th Armoured division they were attached too. The crew had side shields but from what I've read they were seldom used. The gun could of course be dismounted and dug in if necessary and I think but I'm not sure the Portee had a power winch to help loading the 6 pounder.
Cosimodo
#335
Posted: Monday, December 25, 2017 - 05:38 AM UTC
Thanks Chris, interesting approach but it must of had a limited field of fire. Early form of mobile artillery I guess.
The Spit has it basic colour set now. The last week spent painting and masking.
I will fix all the usual oversprays that comes with my masking attempts and them move onto the markings.
Posted: Monday, December 25, 2017 - 06:30 AM UTC
Well, now that my Hangar Queens are out of the way, I'm back on the P-40N. Got the canopy masked and installed. Fuel tank seams are filled. Need to get the engine and cowling next.THen I need to figure out how to airbrush in the cold.
PasiAhopelto
KitMaker: 236 posts
AeroScale: 134 posts
Posted: Sunday, December 31, 2017 - 12:59 AM UTC
There's only a month remaining, so I must speed up Snipe build:
I really like the oversize WWI markings. Just fill all available space The "2" was quite tricky to place. It's shaped like number two (without transparent film in between), which led to positioning being very difficult. For a moment I thought I'd ruin the decal, so would finish the build, but not in this Campaign. But it's there now (although not 100% properly aligned).
I think it's upper wing next, and then rigging. Should be doable.
Willard79
Wellington, New Zealand
KitMaker: 189 posts
AeroScale: 179 posts
Posted: Tuesday, January 02, 2018 - 12:14 PM UTC
I've been busy on other things lately, but have been following along nevertheless, lots of good stuff going on.
Now that I'm on holiday, I'm trying to steam through and catch up on my build before work starts up again. Both Sky, and Earth coats are down and the masks for the Dark Green are on for some coats tomorrow.
I decided to go with Pattern 'A' after a bit more research which suggested odd serials equaled pattern 'A' (opposite for spits) and I found some sketchy photos that supported the theory to some degree.
cheers.
deerstalker36
KitMaker: 153 posts
AeroScale: 8 posts
Posted: Wednesday, January 03, 2018 - 12:21 PM UTC
only just noticed this campaign. I've got 2 dioramas on the go but not finished for ANZACs, would they be eligible?
Posted: Thursday, January 04, 2018 - 12:01 AM UTC
Hi Colin rule 7 for the campaign states
7.Hangar queens are more than welcome we want to encourage
the completion of modelling projects. Entry is subject to
the campaign organizer's okay.
If you wish to participate I'm thrilled to have you on board! Please post some pics of your project or projects so we can see what and where you're up to.
deerstalker36
KitMaker: 153 posts
AeroScale: 8 posts
Posted: Thursday, January 04, 2018 - 01:01 PM UTC
Thanks Chris, i have a few works in progress as well for one of them
deerstalker36
KitMaker: 153 posts
AeroScale: 8 posts
Posted: Saturday, January 06, 2018 - 03:52 PM UTC
ok, thanks for allowing me to join. First one is WWII based, with some ANZAC'S on the Kokoda Trail, inspiration from this tin of Anzac biscuits
i used a selection of Dragon and Masterbox WWII figures to get ....
and some aftermarket heads
I did some work on the back to fit equipment
i've placed then in a diorama setting, just waiting for the camera battery to re-charge.
then next one is a WWI setting with the Australian No1 Light Car Patrol in a ford model T in Palestine, photos once the camera battery is charged again
deerstalker36
KitMaker: 153 posts
AeroScale: 8 posts
Posted: Saturday, January 06, 2018 - 05:19 PM UTC
so the WWI submission....
and the figures
the idea is two stood by the car with a 3rd taking a photograph
the Kokoda trail figures have been placed in a diorama, just need to finish painting them
Posted: Sunday, January 07, 2018 - 11:12 AM UTC
back to the P-40N, finally. Got the cockpit framing with coat of the interior green on the canopy frame.
Next up primer!
RhinoSpit
Bas-Rhin, France
KitMaker: 144 posts
AeroScale: 119 posts
Posted: Friday, January 12, 2018 - 03:11 AM UTC
Some advance on my CA-12:
DSC_7204
DSC_7203
DSC_7208
Only bad word come out of my mouth...
No placement pin, strange plastic quality, ...
Pave-Hawk
KitMaker: 843 posts
Posted: Friday, January 12, 2018 - 07:39 AM UTC
Realised I haven't posted any progress shots in this thread yet, so here we are:
It's had a coat of primer since this shot.
Posted: Friday, January 12, 2018 - 11:27 AM UTC
A little further along. Primed and nearly ready for painting.
Willard79
KitMaker: 189 posts
Posted: Sunday, January 14, 2018 - 08:55 AM UTC
It's a little bit comforting knowing I'm not the only one racing the clock on this one, but I think I'm on track (unwarranted confidence is the best confidence).
The markings are on (thanks Miracle Masks), so now a just a small bit of decaling, weathering, final assembly and I'll be done, piece of cake aye?
Anyway, enjoying seeing all the other builds coming along. All the best.
Posted: Sunday, January 14, 2018 - 03:14 PM UTC
Damn fine paint work there Spud! Mals masks are just the shiz right?
