Been slowly working on the Hellcat's Pratt & Whitney R-2800-10W Double Wasp engine.
I made the decision NOT to use the PE ignition wires as they just don't look right being flat, so the 1st step in the wiring process was to remove the square shaped ignition manifold that is molded onto the crankcase cover. Here's the casing without the manifold
The crankcase cover was painted with a custom mix of Tamiya 10 drops of XF-53 Neutral Gray to 1 drop of XF-17 Sea Blue then thinned 2:3 with Tamiya Yellow Cap Lacquer Thinner.
Next was to fashion a round manifold which I made out of 1.0mm round lead wire. I haven't sanded nor polished the manifold as yet in these pictures as it's really quite rough in texture.
then I dry fitted the ignition ring, made final adjustments to it, and then dry fitted the crankcase cover to see how it all looked as one unit.
I decided to add the cylinder gas equalizers both between the cylinders, as well as smaller pipes between each rocker Arm cover. These were all made from .7mm and .3mm lead wire.
Then I primed both banks of cylinders with Mig Ammo Black Primer
After the primer had dried for a day, I air brushed on Alcad2 a/c101 Aluminum. Since the cylinders are caste, I didn't want a smooth nor shiny texture, so the flat primer was a perfect base. I let the Alcad2 dry for a few hours, then applied Tamiya Black panel line wash, and painted the push rod sleeves with Tamiya X-1 Gloss Black.
The next step is to start wiring up the big Wasp.
