Tools & Supplies: Airbrushes
Talk about airbrushes.
Hosted by Matt Leese
Which Airbrush
KitMaker: 3 posts
Posted: Saturday, December 02, 2017 - 04:00 PM GMT+7
Looking to invest in my first single action airbrush just starting out and not too familiar with using one and heard that starting out with a good single action airbrush is the way to go and need some advice on where to start looking to spend about $60 - $80 U.S.
KitMaker: 988 posts
AeroScale: 46 posts
Posted: Saturday, December 02, 2017 - 04:10 PM GMT+7
First it's better if you say how much you can spend and.....I would go straight to a double action AB now you can buy some good ones for starters without spending too much money like Iwata neo or badger patriot 105 (I prefer the second)
KitMaker: 3 posts
Posted: Sunday, December 03, 2017 - 01:03 PM GMT+7
Thanks Vicious for the info.
Arkansas, United States
KitMaker: 11,118 posts
AeroScale: 79 posts
Posted: Monday, December 04, 2017 - 10:43 AM GMT+7
I started, with a double action, siphon fed ab from Harbor Freight. It was a disaster. I moved on to Iwata(very nice). However, I would recommend the Badger Renegade Krome series. It's a dream to use and, with proper set-up can spray a hairline fine. I currently have two of these and all parts, in the series are interchangeable. To clean my brush, I break it down and place all, but the air valve assembly in a jar of lacquer thinner. This is set on my uc and let run for 5-10 minutes. Clean up, between colors is a quick shot of Windex or lacquer thinner. Wipe it out and run a reaming needle, through it a few times. There is not any soft metal visible, so you don't have to worry about etching. I have used the Sotar 2020, as well. It is very simple and allows for a range of spray patterns. With proper care and maintenance, these airbrushes should last forever.
KitMaker: 43 posts
AeroScale: 21 posts
Posted: Sunday, March 18, 2018 - 10:53 PM GMT+7
Most airbrushes will preform similar at any given price point. If your looking for a gun in the say 80.00 to 120.00 range you will find they are all similar in performance. Of course some will feel different in the comfort zone, the size and balance may vary, but they should basically shoot the same depending on needle size. An airbrush is a tool, you need to learn how to handle the tool for best results. There are many good options and I am a cheerleader for no brand. Find what suits you and practice.
KitMaker: 3,058 posts
AeroScale: 6 posts
Posted: Monday, March 19, 2018 - 01:44 AM GMT+7
Don't bother with a single action, buy a double action instead.
I started with a double action, as recommended by others, and had no problems learning how to use it.
I think it is easier to adjust the opening (flow of paint) on-the-fly than having to set the needle first and then re-set it when I find out the opening was too large or too small.
When I paint I use different openings (flow of paint) in the sam session. Large spray coverage for larger surfaces and a smaller opening when painting into small corners such as all the corners on the lower chassis of a tank.
/ Robin
KitMaker: 1,634 posts
AeroScale: 446 posts
Posted: Monday, March 19, 2018 - 09:49 AM GMT+7
Yeah-- I agree with Robin again. My advice is to buy a good double action AB and learn how to use it. I've been modeling since 1959, and I wish somebody had given me that same advice back in the 60's when I was just getting into airbrushing. By the time you spend money on several "good" single action brushes, you'll wish you'd just started with a double action in the first place. There are plenty of inexpensive (relatively speaking) double actions out there that do a great job. By the time you buy a single action, use it for a few models, and wonder why you cant get the same feathered edge and "mottling" and fine lines that other modelers do, you'll wish you'd have bought a double action. True, they are more difficult to learn how to use, but once you master them through practice, you'll be amazed at the results and what you can do with them. But remember, like any fine instrument, they need to be kept clean and serviceable, cleaning them after each use, and storing them properly to avoid damage. You don't by a Ferrari to park it in a junkyard and never change the oil--at least you shouldn't if you expect it to drive properly!
KitMaker: 618 posts
Posted: Monday, March 19, 2018 - 11:12 AM GMT+7
If you feel intimidated by the typical layout of a double action airbrush you can get a trigger type. I'm using a Grex but it cost over $200. You can find a Iwata TRN1 for about $100 if you shop around. Much more intuitive for me than the push pull of the typical double action. Wish they had these types of airbrushes 30 plus years ago when I bought my first double action.
