World War II: Great Britain
Advice requested on the Matchbox 1/32Lysander
KitMaker: 8,194 posts
AeroScale: 329 posts
Posted: Sunday, January 14, 2018 - 11:15 PM UTC
For right or wrong I have now ordered both the Masters brass barrels AND the Gaspatch .303 Browning resin guns. We will see which I end up using.
I was attracted to the Masters barrels because the barrel and heat shield are two separate pieces therefore the undercuts in the heat shields are going to be deeper and more pronounced than the moulded resin items.
Perhaps I will end up using bits of both!
Posted: Monday, January 15, 2018 - 01:09 AM UTC
A wee bit of background:
I went with the 1/32nd scale aircraft because up to now I have always modeled in the fairly popular armor scale of 1/35th. I figured 1/32nd was close enough that my eye would not be too offended seeing the two scales sitting next to each other. (I have always been one to want everything all in the same scale.) But now I understand why 1/48th scale aircraft are so popular.
It started when the L-O-N-G UPS box first arrived. I was kind of blown away right there. Then I opened the carton to again find a very LONG Matchbox model inside. During all this construction the size never really hit me until I attached the landing struts and just for kicks temporarily attached the wings!
Talk about BIG!
I think all future aircraft are going to have to be relegated to hanging off the ceiling. No room here on the display shelf!
Posted: Monday, January 15, 2018 - 01:26 AM UTC
Milestone reached:
Lizzie's got legs! - - - Landing struts attached:
The fuselage continues to be taped together (still) because I cannot seem to stop finding bits and bobs of detailing to add to the interior framework (don't know when this work will ever be complete, will it never end?) but at least the struts are now permanently attached!
Notice how this news is a real head turner for our pilot. (e.g. I thought our guy would look far more natural if his head was not posed so rigidly straight ahead so I turned his head. Now he is posing for the camera - still serious as heck - but at least he is now looking at the camera.)
Posted: Monday, January 15, 2018 - 01:27 AM UTC
A little sidebar: I have since added the chart table to my model. I rather enjoyed doing this small piece. A bit of trivia here - the map used is a reproduction of an actual captured German WWII map of south eastern France that I have in my historical paper collection.
(The same map can also be seen folded in the pilot's cockpit map pocket.)
Posted: Monday, January 15, 2018 - 04:27 AM UTC
The beauty shot(s):
Photo credit Stephen Fox/Airliners.net
Photo credit Tucker Harris Collection
All photos posted for discussion purposes only.
Posted: Tuesday, January 16, 2018 - 03:53 AM UTC
Something of interest:
Experimental Lysander with mocked up quad enclosed turret. A flying prototype was never built as it was determined that the field of fire for the turret was too limited to be effective.
Posted: Tuesday, January 16, 2018 - 10:34 PM UTC
However here is a turreted Lysander that WAS built!
This aircraft never went into production - only two ever built.
Posted: Tuesday, January 16, 2018 - 10:38 PM UTC
I know I am jumping all around but here is an interesting image that I just found:
Complete airframe:
Shows wing spar tower but ALSO clearly shows pilot's and navigator's "rings".
Posted: Wednesday, January 17, 2018 - 01:47 AM UTC
I think my interior bracing work and detailing of the fuselage is complete. (NOT to say the detailing work on the airframe is finished!)
I plan to show both cockpit side windows in the down position. I will therefore cut some clear plastic sheet, mask it to paint the window dividers and add these to the interior of the model.
Cockpit window in the down position. First of two installed.
Posted: Wednesday, January 17, 2018 - 02:10 AM UTC
A bit hard to see but more detail (controls and cables) have been added to the structural frame, primarily around the pilot's cockpit. Focusing now on the gunner's area and waiting somewhat anxiously for those twin Browning weapons to show up from Gaspatch and Master!
(Little or no progress on rebuilding the pilot's control panel. I am putting this off simply because this panel will still be removable even after the two-piece fuselage is buttoned up. So it can wait till later!)
Posted: Wednesday, January 17, 2018 - 12:11 PM UTC
Pilot's cockpit coming together. - Gunner's spot is another subject - much more work to come.
Posted: Thursday, January 18, 2018 - 09:36 AM UTC
When I saw the engine mount ring on that image of the early Lysander airframe I just knew I was going to have to add it to my model. (Even though once the fuselage is closed up you will never see it again.)
Posted: Thursday, January 18, 2018 - 09:54 AM UTC
Here is where I am on building the gunner/navigator/radio operator's ring. Still waiting for my twin Brownings to arrive!
Here is a photo of the actual ring:
How about that seat? - looks like nothing but a round bar stool - I have seen two different PE sets (in other scales) that make this seat look like a butt shaped, stamped, rectangular tractor seat. Who/which is correct? That poor gunner has a hard life back there! (And/or he must have a very hard A$$.)
Posted: Thursday, January 18, 2018 - 10:55 AM UTC
It really bothered me that the rear canopy was not deep (tall) enough to reach the tracks molded in the sides of the fuselage on the model. Also the molded grooves did not extend far enough down the side of the aircraft to give the impression that the rear canopy could actually function.
The solution to both these problems was to add the channel slides to the sides of the aircraft.
I have now also added a flange to the bottom of this canopy. With this addition the glass will almost sit properly on the slide tracks. When I finally glue it on just a slight pressure while the glue is drying and it will sit properly.
If you look at the righthand photo above you can just make out this flange.
(I may want to sand that flange a bit thinner.)
Posted: Friday, January 19, 2018 - 07:57 AM UTC
Just found another photo of the twin Brownings! (Still doesn't help with the gun mount.) However it does show the two large cartridge magazines which is new information.
It appears the belts pull from the bottom of the magazines. That seems strange as that would mean the full weight of the ammo belts sit on the portion of the belt being pulled out???
Anyone have any ideas.
(I don't think I'm right on that. It just would not work that the belts pull from the bottom.)
KitMaker: 978 posts
AeroScale: 833 posts
Posted: Friday, January 19, 2018 - 08:26 AM UTC
Michael - interesting and a good observation. Although it seems unlikely, perhaps the belts do not lay in the magazines horizontally but instead are loaded in a vertical serpentine fashion. Hmm - any automatic weapons folks out there who can help ?
Richard
Removed by original poster on 01/20/18 - 17:36:22 (GMT).
Posted: Friday, January 19, 2018 - 10:39 PM UTC
I spent a good portion of last night looking for some photo reference on the large box ammo magazines that feed the twin Brownings in the Lysander. So far no luck. All I could find were the smaller box mags that actually hung on the sides of some guns.
Good reference on the Browning but no help on the Lysander project.
Posted: Saturday, January 20, 2018 - 09:05 PM UTC
Another item for the 1/32nd Lysander that I found but failed to mention earlier: The canopy painting masks from MonteX.
I would say this is an excellent product, however I must admit this is my first time using a pre-cut mask for doing this type of glass work. (Masking the glasswork has always been my most feared aspect of building model aircraft - a fear carried over from my childhood building an otherwise rather nice B-25 Mitchell only for it to be ruined when I tried to hand paint the window divisions.)
KitMaker: 1,711 posts
AeroScale: 1,660 posts
Posted: Saturday, January 20, 2018 - 09:44 PM UTC
Michael! I'm following this with interest! The Matchbox 1/32 series from the late 70s were a fun bunch of kits, I wonder how they picked the subjects ! I can understand why they did the 109 but both the Sea Venom and your Lysander are fairly odd subjects. Never mind, it is something to be happy for today since I wouldn't hold my breath waiting for someone else to do one in that scale. And not a Puma helicopter either !
Posted: Saturday, January 20, 2018 - 10:51 PM UTC
Magnus I must admit - I enjoy the fact that the kit is as old as it is but; (relatively speaking) still as good and well detailed as it is. It has been a pleasure to build and to also add detail to this one. This construction adventure is sort of my first foray into large scale aircraft models in a very long time and I like that it did not require investing an arm and a leg to get started. (The low price leaves lots of $$$ room to purchase extra details and AM parts for the project.)
Thank you for your positive comments.
Posted: Sunday, January 21, 2018 - 01:43 AM UTC
Out shopping on eBay again. The Lysander bird is going to need some seatbelts. I have my fingers crossed - the shoulder belts look correct but I am not so sure about the buckles. Anybody have knowledge on the subject of early war British aircraft seat belts?
Posted: Monday, January 22, 2018 - 03:03 AM UTC
I received my brass Browning barrels from Master Models today but unfortunately I had ordered the wrong ones! (My BAD! Missed ordering the correct item by just one digit!)
The ones I received could be used, yes, however the barrels lack the distinctive end-of-barrel heatsinks and flash hiders. (The flash hiders were not used on the Lysander but they look cool and I might apply a little artistic license on this one.)
I am reordering.
Posted: Monday, January 22, 2018 - 06:25 AM UTC
Up to my old tricks again: If I can find reference on more interior braces and spars I will probably add them right up to the last second before I close up the hull.
Posted: Monday, January 22, 2018 - 06:43 AM UTC
Been busy; This is the first time ever that I have attempted to mask and paint a canopy. Make no mistake I did not do that good of a job. This glass won't win any awards. These parts would not survive a close inspection. I started on the flat side panels and improved some as I moved towards the curves pieces.
I brushed the interior color on first and then sprayed the exterior color, finishing up with a shot of matte clear.
The interior color was a bit of a disappointment, the color looks way too dark because the light that illuminates this color must first travel through the glass and then be reflected back to again go through the glass a second time. This changes the color shade and darkens it unrealistically.
