OFFICIAL: Bombers 2 Campaign
RhinoSpit
Bas-Rhin, France
KitMaker: 184 posts
AeroScale: 158 posts
Posted: Tuesday, March 12, 2019 - 09:05 PM UTC
i can see the finish line
KitMaker: 4,475 posts
AeroScale: 2,941 posts
Posted: Tuesday, March 12, 2019 - 11:52 PM UTC
Neat. Tell us more about the NMF on the nacelles, how did you do it?
KitMaker: 4,766 posts
AeroScale: 2,573 posts
Posted: Wednesday, March 13, 2019 - 04:40 AM UTC
Franck, I also would like to know.
eMan
#298
Hong Kong S.A.R. / 繁體
KitMaker: 1,092 posts
AeroScale: 312 posts
Posted: Wednesday, March 13, 2019 - 12:01 PM UTC
Lancaster BI No.467 Squadron, No.5 Group finished.
KitMaker: 3,498 posts
AeroScale: 2,540 posts
Posted: Thursday, March 14, 2019 - 02:16 AM UTC
Nice work Eman!
KitMaker: 266 posts
AeroScale: 251 posts
Posted: Thursday, March 14, 2019 - 06:11 AM UTC
Hi All,
Lap, nice finish!
I've been working this one hard. Not a hard kit, just big and a bit ungainly. Makes for cumbersome moves.
Michael, thanks for the extension! Can't work on anything but this one per the commander, so I'm pleased that it's going as good as it is!
Decals going on, and soon done!
Have fun! More to follow.
John
RhinoSpit
Bas-Rhin, France
KitMaker: 184 posts
Posted: Thursday, March 14, 2019 - 07:58 AM UTC
Hello,
first i've airbrushed a coat of alclad gloss black primer, then a coat of alclad polished aluminium and finally i airbrush lightly a coat of alclad burnt iron.
KitMaker: 266 posts
Posted: Tuesday, March 19, 2019 - 04:32 AM UTC
As I limp back to base, my worst fear is realized. I've got a tail dragger! Despite 157 grams of weight!!
Reevaluation, found that I didn't include the rear turret, or the waist area in my initial weight calculation. Based on the weight of the protective cloth and a lighter... Me thinks another 20 grams. I'll know for sure tomorrow.
KitMaker: 266 posts
Posted: Tuesday, March 19, 2019 - 04:05 PM UTC
Greetings all!
After some sleep, I was able to pound out some more 1 gram weights. Adding 10 at a time, it took 30 grams. That plus the 157, and add to it the 3 ml superglue, and 4 ml of epoxy, it comes to 196 grams. So let's just say 200 grams (7.0 ounces). It's a lot of weight, but the structural nature and strong landing gear take it with no problem!
Now, gear doors, gun barrels, and pitot tubes. Then off to the blue cloth for pictures!
Have fun,
John
Posted: Tuesday, March 19, 2019 - 04:33 PM UTC
John, nice job. Now where are you going to park that monster?
Posted: Thursday, March 21, 2019 - 08:31 AM UTC
Hey, it's starting to look a little like a bomber.
KitMaker: 266 posts
Posted: Friday, March 22, 2019 - 06:19 PM UTC
I'm calling this one done!
Overall the kit is a straight up build. The wings need a bit of work, as does the tail section. Though, nothing a modeler with a couple of kits under their belt can't handle. The biggest challenge is the size! This is a big one, so all the seam filling takes longer. With patience and the Eduard mask set it's a pretty easy build. Just takes a little longer!
A shot to give some scale, as you can see it's big!
And Bob, in answer as to where does it go? Well, on the Big Bird Table of course! Until I get a display case!
Happy modeling!
Posted: Sunday, March 24, 2019 - 06:23 AM UTC
I'm really beginning to love Alclad.
Almost makes me look like I know what I'm doing.
Clear coat, white on the rudder and I'm off to the decaling.
Posted: Sunday, March 24, 2019 - 08:57 AM UTC
Mark, she looks nice and I have been afraid to try the Alclad since I only use acrylics.
Waiting to see your ship finished.
Posted: Sunday, March 24, 2019 - 11:05 AM UTC
Bob, this is my second try. The first one went pretty good too. I think a big pat of the secret is to use their gloss black primer. I shot the primer with my Badger 105 with a 0.5mm needle, it ran through the paint quickly, had to refill the bowl halfway through. Used my Neo CN, 0.35mm needle for the aluminum much lager bowl but it still needed a refill halfway through. In both cases, I shot it straight out of the bottle, no thinning.
I've used both acrylics and enamels on the inside of this one.
Posted: Saturday, March 30, 2019 - 05:06 PM UTC
Soooo close. Almost all of the fiddly bits installed. New decals printed, almost ready to apply.
I might make it, I might make it.
Posted: Sunday, March 31, 2019 - 03:59 AM UTC
You can do it Mark! Don't forget, you have until the end of the day tomorrow, 1 April!
RhinoSpit
Bas-Rhin, France
KitMaker: 184 posts
Posted: Sunday, March 31, 2019 - 06:00 AM UTC
My Blenheim MK.IV is finished.
Posted: Sunday, March 31, 2019 - 09:48 AM UTC
Franck, nice job on your Blenheim. What paint did you use?
Mark, the next time I build an a/c that needs NMF I will ship my a/c to you to paint. I love the NMF what you've done.
Posted: Sunday, March 31, 2019 - 10:35 AM UTC
Don't look too closely, I managed to strip off some of the Al topcoat when I masked to paint the rudder. And a seam line list it's aluminum too. I've got some AM decals for the Star and dot national insignia, but the rest of the original decal sheet is toast. SO I scanned them into MS Paint and tried the fix them and print them out on clear decal sheet. I sure hope this works.
KitMaker: 266 posts
Posted: Sunday, March 31, 2019 - 03:01 PM UTC
Mark,
I know you can finish it!!! The Alclad II went down nice, and I like how you did it. I do it similar, though I use Mr Surfacer 1500 black, and get really good results at a cheaper cost. I really like the stuff, for NMF it's the best way to go if your on a budget. Almost any gloss black will work. I've seen modelers use Rust-o-lum gloss black and get great results. The trick is to lay the black down, let it dry thoroughly, and then light sprays of Alclad, but not too much!
RhinoSpit
Bas-Rhin, France
KitMaker: 184 posts
Posted: Sunday, March 31, 2019 - 07:19 PM UTC
i've used Tamiya Desert yellow (XF59) and Earth (XF52) for the upper surface and Vallejo UK Azure blue (71.108).
Now it's time for a two weeks break, i'm leaving my appartment.
iflytb20
#501
Kerala, India / भारत
KitMaker: 275 posts
AeroScale: 180 posts
Posted: Monday, April 01, 2019 - 03:46 AM UTC
Anyone else having issues in uploading pics to the kitmaker gallery?
Posted: Monday, April 01, 2019 - 04:02 AM UTC
No problems lately, but the gallery is finicky. If your image is over a certain size, say 3Mb, it will act as if the image loaded, but not actually do anything. You've got to go under that limit. I use my photo editor, Imgur, to resize the image to 1024 by 8xx and it usually goes in just fine.
Posted: Monday, April 01, 2019 - 05:05 AM UTC
I use paint and resize mine to 825.
