Eduard 1/48 Spitfire Mk.IXc early
Venko555
Bulgaria
KitMaker: 775 posts
AeroScale: 203 posts
Posted: Tuesday, March 06, 2018 - 11:24 AM UTC
Hello!
Although I have some unfinished projects, I'm starting this new aircraft build, because I really like the desert camouflage on those Spitfires. Kit is 8282 from Eduard.
I chose the Stanislav Skalski's airplane, a Polish ace. The US markings are also interesting, but I'm already building an American Spitfire .
I bought also resin top cowl replacement (must have and cheap, because the plastic part is from two pieces) and doors for the cockpit.
I would also like to share my highly positive experience with Eduard customer support. There was sprue missing with the large bulged gun covers, which made building most of the variants (including the desert ones) impossible.
Contacted them on the same day, very fast reply and the missing parts were here after 4-5 working days for free. So they are very best in that
Venelin
Willard79
Wellington, New Zealand
KitMaker: 188 posts
AeroScale: 178 posts
Posted: Tuesday, March 06, 2018 - 01:07 PM UTC
I do like a good Spitfire build, especially an Eduard.
KitMaker: 6,629 posts
AeroScale: 6,039 posts
Posted: Wednesday, March 07, 2018 - 07:06 AM UTC
Will follow your build .
KitMaker: 8,693 posts
AeroScale: 7,228 posts
Posted: Monday, March 12, 2018 - 08:02 PM UTC
Venelin,
Eduard Spitfire Mk.IXc early or late versions are exceptional kits. I'll be following your build to it's conclusion for sure.
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Monday, March 12, 2018 - 09:45 PM UTC
Will start soon, but there's some finishing work on the Tamiya Spitfire.
I'm so impressed by the detail here, even the exhausts are hollowed
Venelin
WIggus
KitMaker: 55 posts
AeroScale: 51 posts
Posted: Monday, March 12, 2018 - 10:29 PM UTC
I'm building an Eduard 1/72 Mk.IX right now. If its quality is any indication, you are in for a good time. :-)
squidgy
#144
KitMaker: 268 posts
AeroScale: 10 posts
Posted: Tuesday, March 13, 2018 - 10:02 AM UTC
looking forward to your build, can you check the fit of the top cowl, as i have purchased 5 of them (combination of the early and late cowl) and only one actually fits properly, they are 1mm too long, i had Eduard send me replacements and they are exactly the same, not sure how to overcome that issue without losing detail on the cowl,
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Tuesday, March 13, 2018 - 10:37 AM UTC
I will check this, thanks! I thought it is drop fit.
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Tuesday, March 13, 2018 - 05:56 PM UTC
Yep, sadly the resin cowl is 1mm longer and it will be impossible to correct it without damaging the fine detail. The flush rivets are also misaligned. I think I will use the kit one, although from two parts.
Posted: Tuesday, March 13, 2018 - 11:22 PM UTC
Venelin,
I also used a Resin one piece cowl rather then the kit two piece affair, as there was so many posts that the seam just was impossible to deal with. I really don't remember if I had to sand the front down, but I'd go that route rather then having to deal with the seam.
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Tuesday, March 13, 2018 - 11:37 PM UTC
Maybe a little sanding from both ends will do the job
Posted: Wednesday, March 14, 2018 - 01:12 AM UTC
Venelin
I'd certainly go that way as you have nothing to loose and everything to gain. You're looking at 1/2mm on either end which is almost nothing.
Willard79
KitMaker: 188 posts
Posted: Wednesday, March 14, 2018 - 02:54 AM UTC
That's a bit disappointing, especially as it's Eduard resin for Eduard. I have some Barracudacast ones, but haven't checked how they fit.
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Wednesday, March 14, 2018 - 09:30 AM UTC
Actually, with some careful sanding the fit is good . I was afraid not to compromise the detail, but it tuned out quite well. Again, be very careful when sanding
bomber14
KitMaker: 228 posts
AeroScale: 210 posts
Posted: Wednesday, March 14, 2018 - 06:04 PM UTC
venelin i will be following too. i have the late version so i guess the cowl is the same there too. can i ask if there is a trop filter in the kit and what part # it is? not too familiar with spits.
joe
Venko555
Bulgaria
KitMaker: 775 posts
Posted: Wednesday, March 14, 2018 - 06:33 PM UTC
Joe,
There's different resin cowl for the late IXc. I'm not sure for the filter, not very familiar either, there are parts E5 and E6 not used, that looks like.
Venelin
Posted: Wednesday, March 14, 2018 - 07:03 PM UTC
Venelin
Looks perfect. I always expect some needed adjustments when working with AM resin parts. That way, when none is needed it's a pleasant surprise, but when some adjustments are, I'm prepared for it.
squidgy
#144
KitMaker: 268 posts
AeroScale: 10 posts
Posted: Thursday, March 15, 2018 - 05:29 AM UTC
awesome job, great to know it can be addressed as i have 5 of them, following your build !!!
