SBD Dauntless
amigo1941
Auckland, New Zealand
KitMaker: 61 posts
AeroScale: 13 posts
Posted: Wednesday, November 21, 2018 - 04:28 PM UTC
Hi. I'm planning on building a ww11 Pacific Ocean SBD(1/48th scale) in the two tone scheme and would be greatful for some input on the colour of the upper surfaces. I normally use gunze sangyo or tamiya acrylic paints so mixing formulas would be of great help.
B_Ernie
#266
KitMaker: 46 posts
AeroScale: 11 posts
Posted: Thursday, November 22, 2018 - 12:40 AM UTC
The following link should be enough to provide you with the information you need.
https://www.google.com/search?q=sbd+dauntless+paint+schemes&num=50&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjBzNvfgujeAhUTMH0KHSm7CccQ_AUIDigB&biw=1723&bih=927
KitMaker: 3,275 posts
AeroScale: 2,358 posts
Posted: Thursday, November 22, 2018 - 02:16 AM UTC
Les,
I've seen the color matched to FS35189 which seems pretty close to me. At least one online Tamiya paint mix chart that I think has been floating around for years shows a mix of 3 parts XF-18 Medium Blue to 1 part XF-2 White, which I think is effective (if I remember correctly from the last time I did it, I may have added a little black back in). Your mileage may vary.
I don't have easy access to Gunze so not so sure about it.
Given the number of kits of early USN WWII aircraft out there, it's a shame Tamiya and Gunze don't do a dedicated color for it, but there you are.
Hope this helps!
Removed by original poster on 11/24/18 - 07:20:09 (GMT).
amigo1941
KitMaker: 61 posts
AeroScale: 13 posts
Posted: Friday, November 23, 2018 - 08:25 AM UTC
Hi. Thanks for that but I have been there and its a quagmire. I was hoping for a modeler that had built this aircraft and had an accurate paint formula that he/she used. Even a nod that the Academy SBD-2 paint instruction colors are correct.
