Scratchbuilders!: Armor/AFV
Hosted by Mike Kirchoff
Flak 88. 36.37
avro539
KitMaker: 7 posts
Posted: Wednesday, December 05, 2018 - 11:41 PM UTC
Hi Just a few words to start this build off...It's a Flak 88 36 mounted on a Sd.Anh.202 trailer...The size will be 1/6 scale...I have to scratch build it as the Armortek kit is no longer available and I couldn't afford 4K English pounds which is double in dollars where I live " just ridiculous "
I will use alloy steel and brass.. Have got plenty of Pics and some measurements to get me going.....might take a few weeks to get started as I need to purchase several different size alloy square- round bar and 3-5mm sheet..
The length approx just over 1 meter 300 high..a future project will be a Sd.Kfz.8 series DB9 Half track to tow the Flak 88
Havent thought about camouflage paint detail but like North Africa sand yellow
Namabiiru
#399
Rhode Island, United States
KitMaker: 2,637 posts
AeroScale: 296 posts
Posted: Thursday, December 06, 2018 - 12:45 AM UTC
Wow! Can't wait to see your progress!
ericadeane
Michigan, United States
KitMaker: 3,940 posts
Posted: Tuesday, December 11, 2018 - 02:12 AM UTC
Sounds great! If I can make a suggestion -- make sure you research which variant you wish to build. The 8.8cm Flak 36 and the 8.8cm Flak 37 were different guns based on upgraded equipment -- there was no such thing as a "Flak 36/37".
I wrote an article a few years back about the differences if you care to look: http://www.track-link.com/articles/1203
avro539
KitMaker: 7 posts
Posted: Wednesday, December 12, 2018 - 11:00 AM UTC
Hi Roy Thanks for the infomation..no doubt I will need more as I move along.. The Unit will be 36 ..A lot of the pics and information I have refer it as 18.36.37..... I can see the difference in the 18 series but the 36.37 dont look that different to me..must be minor
Could you please explain the difference as I haven't found any information except that it had a separate gunfire control and a pointer on the elevation scale..
Most of the information I have referred the gun as Flak88 18/36/37 or Flak 88 18/36 or Flak 88 36.37...I know everybody has their own interpretation but it can be confusing ..as I not a Armor specialest I rely on what I read...I just like building things
avro539
KitMaker: 7 posts
Posted: Tuesday, December 18, 2018 - 10:01 PM UTC
Hi Had a big chunk of alloy bar turn up today..160mm diameter x 100mm long..I have to cut a 30mm biscuit off this....These two pieces will make the gun turrent..This will keep me busy on the lathe for a few days
