Modeling Questions?
1/35 & 1/48 model holders
CZACZAJA
Volyn, Ukraine / Україна
KitMaker: 11 posts
Posted: Tuesday, August 20, 2019 - 08:54 PM UTC
Hi Guys,
Im getting into 1/35 & 1/48 AFV models and was wondering what do you use to hold the model as to not handle it too often and have the paint strip when pinwashing/detail painting/chipping etc?
It was easy with 1/72 as i just made custom LEGO holders and the models were light enough to hold on but with such large models its not going to work.
Tried blue-tacking a Tamiya lid to the underside but that didnt hold for long.
Staff MemberTOS Moderator
KitMaker: 6,186 posts
Posted: Wednesday, August 21, 2019 - 01:23 AM UTC
Tanks with removable turrets are easy, just take off the turret.
Other vehicles are tricky.
I would do the work in stages so that there is always something dry to hold on to. The last finishing touches can be done with some care with the model standing on a raised surface (a couple of kit boxes on top of the work bench).
/ Robin
barkingdigger
KitMaker: 3,743 posts
Posted: Wednesday, August 21, 2019 - 09:58 AM UTC
Try good old masking tape on the underside of the hull, sticking onto a bit of wood to act as a handle/stand. Years ago I cut some scraps of 1x2" wood into short pieces that I screwed to 6" strips of 1x2 so the short piece was standing upright in the middle of the strip. Then I put masking tape doubled over with the sticky side out and press the model (or its separate parts) on the tape for painting. You can cut different scraps of wood to fit different purposes (narrow ones to fit inside turrets, for example) and by replacing the masking tape it's ready for the next build...
CZACZAJA
KitMaker: 11 posts
Posted: Wednesday, August 21, 2019 - 06:17 PM UTC
I was thinking about getting one of the work holders like this:
http://www.greenstuffworld.com/en/working-tools/609-universal-work-holder-small.html
and drilling 4 small holes in the tanks underside and then expand the jaws to secure it in place
southpier
KitMaker: 536 posts
AeroScale: 16 posts
Posted: Wednesday, August 21, 2019 - 10:17 PM UTC
not being a "tanker", yet never missing the opportunity to express an opinion of something of which I know nothing . . .
if you are going to ventilate the hull of your model, could you use a jewelers pick-up tool?
https://www.amazon.com/SE-860PT-Pick-Up-Tool-Prongs/dp/B000RB3KZ4/ref=pd_cp_201_1?pd_rd_w=lpAxh&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=Z4693BKZWBSR5TZYN3Y4&pd_rd_r=b3807362-cc29-447a-902f-03d03fb36fbd&pd_rd_wg=nrOly&pd_rd_i=B000RB3KZ4&psc=1&refRID=Z4693BKZWBSR5TZYN3Y4
the holes could be small and covered by some detailed wash-out plugs or panel at final construction.
I understand this treads (!) on the controversy of detailing what cannot be seen, but that's how I roll.
CZACZAJA
KitMaker: 11 posts
Posted: Wednesday, August 21, 2019 - 11:43 PM UTC
Thats pretty much what I was thinking about with the work holder.
Im not sure the jewellers tool will be sturdy enough to hold a metal 1/48 or 1/35 chassis
