Scratchbuilders!: Ships
This is a group for ship scratchbuilding questions, topics and projects.
Hosted by Mike Kirchoff
1/350th Ropes,how to make them
Wolf-Leader
New Hampshire, United States
KitMaker: 1,214 posts
AeroScale: 55 posts
Posted: Wednesday, August 21, 2019 - 01:50 PM UTC
I would like to know how do you make 1/350th scale ropes? What material would you use to make the ropes out of?
Thank you.
KitMaker: 3,058 posts
AeroScale: 702 posts
Posted: Wednesday, August 21, 2019 - 04:10 PM UTC
What type of "ropes"?-- There are all kinds-- halyards, antenna, cables, hoses, etc. it would help to know what you are after. I use a combination, depending on what I want to represent. Here's a few I use: antennas are generally made from thin nylon "magic thread" or Berkshire Industries "EZ line". Occasionally I'll use 2lb or 4lb fishing Leader. Supporting lines and halyards might be made of fine wire or thread which is waxed, depending on the thickness desired. Deck ropes might be coiled from thin silk thread which is waxed. Cables are usually thicker waxed black or dark gray thread. (Waxing is done to prevent fraying and ease forming). Hope this helps answer your question.
Removed by original poster on 08/22/19 - 09:42:57 (GMT).
Wolf-Leader
AeroScale: 55 posts
Posted: Thursday, August 22, 2019 - 06:16 AM UTC
Russ,
I'm looking to make deck ropes for my U-Boat in 1/350th.
Biggles2
KitMaker: 7,151 posts
AeroScale: 118 posts
Posted: Monday, August 26, 2019 - 02:22 AM UTC
If it's just ropes (hemp) used for mooring, then a fine sewing thread would work, waxed (as noted above) to eliminate the "fuzzies".
