Armor/AFV: Large Scale
1/16 and Larger Armor Modeling
Building a 16th. Panzer IV Ausf. F
OldWarloke
KitMaker: 2,315 posts
Posted: Tuesday, November 12, 2019 - 02:45 AM UTC
I'm starting another Large Build, I hope you Guys like it.
I'm starting with the engine, I know it's not quite accurate but most of it can't be seen .
More later.
Donald
Scarred
KitMaker: 1,277 posts
AeroScale: 24 posts
Posted: Tuesday, November 12, 2019 - 06:11 AM UTC
I got the Ausf H version of this kit and I want to detail out the engine and engine bay, was thinking of getting the resin version or the 3d printed one from Shapeways. Neither are cheap tho.
OldWarloke
Posted: Tuesday, November 12, 2019 - 08:12 AM UTC
I built the Ausf.H version about 4 years agoe. If you want it here's a link to the Pics from My build posted on this site .
https://1drv.ms/u/s!ArouE_A-TfGG3AHFfNHcQSody-NW?e=U2765J
I highly recomend the ATTAk Resin Zimmerit that is shown here.
Unless you are going to open the whole engine deck I wouldn't worry about the Engine as hardly any of it can be seen through the Engine Hatches.
Hey check out the Pics. you'll see what I mean.
Hope this helps.
Donald
I'm not shure if the whole thing coppied, any way here's it again.
Scarred
AeroScale: 24 posts
Posted: Tuesday, November 12, 2019 - 11:08 PM UTC
yeah, Thanks for the link I was looking that the Atak zimm already. I want to leave the grills loose so you can open them up and see the engine compartment. Thinking of leaving all the hatches open to show the detail. Lot of parts shame to hide them.
HarrisHawk
KitMaker: 20 posts
Posted: Wednesday, November 13, 2019 - 04:38 AM UTC
I'll be following your build closely, with much interest. I almost went the resin engine route myself, but your excellent pics of your engine in your other PzIV build made me reconsider, along with the price of the resin engine kit. Thanks for sharing with us.
OldWarloke
Posted: Wednesday, November 13, 2019 - 10:09 AM UTC
If you stick with me, I'll be showing you all how to hinge most of the hatches so you can open and close them. that'll be coming up eventually.
Donald
Ps. that includes the engine hatches.
OldWarloke
Posted: Wednesday, November 13, 2019 - 10:51 AM UTC
I did some more on the engine, most of this can't be seen but the Belth if they are missing will be noticible.
First I slightly flattened 4 lengths of fine solder, then super glued them to the bottom of the bottom pully.
Trim off the extra and super glue in place.
Finished for now.
Donald
KBalczo
KitMaker: 26 posts
Posted: Wednesday, November 13, 2019 - 03:34 PM UTC
I always find your builds educational and entertaining, with just a whiff of dry humour. Your "type over" narrative style is greatly appreciated. Unfortunately, my talent and knowledge is lacking, so all I can do is sit back, be silent supporter, and open up another bottle of Pinot Noir.
OldWarloke
Posted: Thursday, November 14, 2019 - 05:58 AM UTC
I've been trying for the wet humor, but I get half way through the bottle and fall asleep.
Donald
OldWarloke
Posted: Thursday, November 14, 2019 - 06:00 AM UTC
Well here's the Engine for what it's worth, You'r not going too see much through the hatch. oh well
I'll be doing the Generator (APU) next, it's under the Radiator so can't be seen at all.
Finished for now.
Donald
HarrisHawk
KitMaker: 20 posts
Posted: Thursday, November 14, 2019 - 04:45 PM UTC
I really like the belts you improvised, something so small, adds so much to the model,IMHO. What size/gage solder did you use?
OldWarloke
Posted: Thursday, November 14, 2019 - 10:19 PM UTC
It's from an old solder coil I got from Radio Shack years agoe.
The coil size reads .032 now if that's mm. or inches , I don't know.
Hope this helps.
Donald
OldWarloke
Posted: Friday, November 15, 2019 - 08:20 AM UTC
Here's the Generator (APU) that comes in the kit. Accurate(Probably Not)
OldWarloke
Posted: Friday, November 15, 2019 - 08:23 AM UTC
I just built this to show what they give you in the kit. This assembly really doesn't matter because it's burried under the Radiator and can't be seen.
There's not much in the Engine compartment, No Wiring Hoses or any thing else. Even the Exhausts aren't hooked up
Well next it's on to more visable and important things like the Transmission and some other interior parts.
Regards.
Donald
OldWarloke
Posted: Saturday, November 16, 2019 - 09:57 AM UTC
The Transmission is finished.
There are 2 parts # B5 & C37 that go on top the Transmission the instructions aren't really clear, here is where they go.
OldWarloke
Posted: Saturday, November 16, 2019 - 10:05 AM UTC
Now a little work on the Ammo Bins.
You really need a Bender for this.
Just bend them and stack in order.
The main bin is a little different, the flanges go down & they are glued to the back before the sides are added.
Be shure to keep the holes lined up.
Done for now.
Donald
chauvel
KitMaker: 142 posts
Posted: Saturday, November 16, 2019 - 01:48 PM UTC
Hope this helps.
Donald
I should think that would be 32 thou. 0.032mm (i.e. 32 thou of 1mm is almost impossible to see & = 0.512mm in 1:1 scale)
OldWarloke
Posted: Tuesday, November 19, 2019 - 06:32 AM UTC
Have a little painting done on some sub-assemblies
Lower Hull sides painted White , then masked off for the Red Primer.
OldWarloke
Posted: Tuesday, November 19, 2019 - 06:38 AM UTC
I have the Generator & Transmission painted I'll add some detail to the Transmission later, but not to the Generator. It's burried under the Radiator, and can't be seen.
The Ammo Bins
There's a lot of push pin marks in the Engine side of the firewall , don't worry about them as they can't be seen through the Hatches.
OldWarloke
Posted: Tuesday, November 19, 2019 - 06:44 AM UTC
The same thing but with the Red Oxide Primer
That's all for now.
Donald
Langemarck
Belgium
KitMaker: 20 posts
Posted: Wednesday, November 20, 2019 - 12:00 AM UTC
Hi Donald. I'm currently building some Takom Panthers with interior, and i'm blocked for the moment because I can't find the correct match for the red oxide primer. So I'm wondering what paint brand you are using
OldWarloke
Posted: Wednesday, November 20, 2019 - 08:49 AM UTC
You won't get an exact color match, there are too many variables.
I use a mix of Tamiya 23ml bottle of XF7 Flat Red to this I add 1/2 to 1 Teaspoon of Tamiya XF64 Red Brown.
The more XF64 the deeper the color will be the less of course the lighter it will be.
Hope this helps.
Donald
OldWarloke
Posted: Wednesday, November 20, 2019 - 08:53 AM UTC
Now I'll be doing some install on the interior.
OldWarloke
Posted: Wednesday, November 20, 2019 - 08:57 AM UTC
OldWarloke
Posted: Wednesday, November 20, 2019 - 09:02 AM UTC
Be shure the Shafts match up.
